K9cop1142
Dec 20, 2020Aspirant
AC2200 nighthawk extender.
Ac2200 is setup if power is disconnected will I have to go back to setup and find and install the extender again, asking in case I want to move extender .
- Dec 20, 2020
its actually done by the router. The extender has to use the same channel the router is on so changing the wireless channel, changes which one the extender uses.
What extender is it? AC2200 is a speed.
What firmware is on it?
Waht router is it connecting to?
K9cop1142
I was having a problem with it connecting back to router, is thgere a way to change channels on the extender so to get which ever is better or is that done by extender.
Dec 20, 2020Guru - Experienced User
