K9cop1142
Dec 20, 2020Aspirant
AC2200 nighthawk extender.
Ac2200 is setup if power is disconnected will I have to go back to setup and find and install the extender again, asking in case I want to move extender .
- Dec 20, 2020
its actually done by the router. The extender has to use the same channel the router is on so changing the wireless channel, changes which one the extender uses.
What extender is it? AC2200 is a speed.
What firmware is on it?
Waht router is it connecting to?
K9cop1142
Dec 21, 2020Aspirant
model ex7700
- Firmware Version: V1.0.0.210
SageMCOM 5260CV router
- plemansDec 21, 2020Guru - Experienced User
I've seen of several people that had issues with the .210 firmware. I'd try downgrading it to the .206 firmware version and then disable auto-updates. skip the .210 version.
