Viktor1979
May 09, 2022Aspirant
AC2200 Nighthawk X4 WiFi Mesh Extender Model EX7300v2 Amber/Orange Led
Hi guys. I need help with this device. It got stuck on the amber/orange LED. I tried to reset it many times but nothing happened. I even tried to upload firmware with TPTP and nothing. It seems ther...
- May 17, 2022
If you can't get it working with tftp or nmrpflash, then it might be a hardware warranty
May 09, 2022Guru - Experienced User
what is orange/amber? What led?
if tftp doesn't work, nmrpflash has worked for some. But even with tftp, its sensitive to timings. sometimes you have to try a few times.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- Viktor1979May 09, 2022Aspirant
It just shows that light with no changing or blinking at all
- plemansMay 09, 2022Guru - Experienced User
try tftp again. again its sensitive to timings.
nmrpflash is a little less sensitive so you can always try that first
Nothing, it keeps running and shows nothing
I think the problem is related to communication. When I set my Network to local IP it doesn´t recognize it. It shows default gateway not available. I tried with 192.168.1.1, 192.168.0.1
