Viktor1979
May 09, 2022Aspirant
AC2200 Nighthawk X4 WiFi Mesh Extender Model EX7300v2 Amber/Orange Led
Hi guys. I need help with this device. It got stuck on the amber/orange LED. I tried to reset it many times but nothing happened. I even tried to upload firmware with TPTP and nothing. It seems ther...
- May 17, 2022
If you can't get it working with tftp or nmrpflash, then it might be a hardware warranty
May 09, 2022Guru - Experienced User
try tftp again. again its sensitive to timings.
nmrpflash is a little less sensitive so you can always try that first
Viktor1979
Nothing, it keeps running and shows nothing
I think the problem is related to communication. When I set my Network to local IP it doesn´t recognize it. It shows default gateway not available. I tried with 192.168.1.1, 192.168.0.1
