Cris1974
Apr 01, 2020Aspirant
AC2200 Nighthawk X4S Tri-band Wifi extender MOBILE PROBLEMS
Good day to all. I hope you all OK.
I have i problem with this wifi extender with phone mobile.
Now is working without problems with all PC, but i have problems with mobile (all Androis S.O.).
Connection with wifi work, but there is non access in internet (only with mobiles).
Someone can helop me ?
Thanks
Cristiano
Did you set it up via wps or the installation wizard?
Any special characters in the ssid or password?
If you set it up via wps, I'd recommend redoing the setup using the installation wizard.
