nathanlejeune
Apr 24, 2023Tutor
AC2200 Wifi Mesh Extender blinking green power light
Hi everyone! I've read all the articles and watched all the videos and am striking out. I have a Nighthawk ac2200 mesh extender which possibly has a firmware corrupted update. I've done ever...
- Apr 24, 2023
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpawIf on Mac, try this guide:
How do I upload firmware to my NETGEAR router using TFTP on Apple macOS? | Answer | NETGEAR Support
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Apr 24, 2023Guru - Experienced User
What are the led's on it actually doing?
What makes you think its corrupted?
- nathanlejeuneApr 24, 2023Tutor
Thanks for the questions! Sorry for being unclear on that.
There is only 1 LED, and that is the power LED which only blinks. It won't reset, it won't connect to the network, and it only sits and blinks the power LED green.
- plemansApr 24, 2023Guru - Experienced User
https://github.com/jclehner/nmrpflash- nathanlejeuneApr 24, 2023Tutor
I couldn't find the mac solution, so thank you for sending me that. I looked everywhere and I'll try those today.
