nathanlejeune
Apr 23, 2023Tutor
AC2200 Wifi Mesh Extender blinking green power light
Hi everyone! I've read all the articles and watched all the videos and am striking out. I have a Nighthawk ac2200 mesh extender which possibly has a firmware corrupted update. I've done ever...
- Apr 24, 2023
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpawIf on Mac, try this guide:
How do I upload firmware to my NETGEAR router using TFTP on Apple macOS? | Answer | NETGEAR Support
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Apr 24, 2023Guru - Experienced User
What are the led's on it actually doing?
What makes you think its corrupted?
nathanlejeune
Apr 24, 2023Tutor
Thanks for the questions! Sorry for being unclear on that.
There is only 1 LED, and that is the power LED which only blinks. It won't reset, it won't connect to the network, and it only sits and blinks the power LED green.
- plemansApr 24, 2023Guru - Experienced User
https://github.com/jclehner/nmrpflash- nathanlejeuneApr 24, 2023Tutor
I couldn't find the mac solution, so thank you for sending me that. I looked everywhere and I'll try those today.
This mac solution worked and I was able to manually update the firmware and get it working again.
Thank you for the help!
Glad it worked!
