Benjammin1776
Dec 12, 2021Initiate
Ac3000 / ex7000
After firmware update, the device started disconnecting intermittently. Sometimes within 30 minutes sometimes less than 30 mins. I already did the power cycle. I also did the reset to factory settings...
Dec 13, 2021Guru - Experienced User
what router do you have? AC3000 is a speed
You have the EX7000 extender?
Is it only the devices connected to the extender that has issues?
What firmware is on the extender and the router?
Benjammin1776
Dec 13, 2021Initiate
I resolved the issue by reverting back to the old firmware. Its all good now. Thanks for the reply
- plemansDec 13, 2021Guru - Experienced User
eitherway glad you g ot it working!
