penanghill
Sep 19, 2020Aspirant
AC3000 no internet connection
My ISP advised me to connect my AC3000 to my tp-link AC1600. The AC1600 is set up as follows: wifi on, WPS off. This created a second wifi network in my home (Orbi wifi + the original wifi). I ...
Sep 19, 2020Guru - Experienced User
A couple things. AC1600 and AC3000 aren't models. They're speeds. Actual model numbers help.
So your current setup is:
CM8200--->Tp-link--->orbi
Is this correct?
Are both the tp-link and orbi running in router mode?
If so, it can put you in a double nat. https://kb.netgear.com/30186/What-is-Double-NAT
Simple fix? put the orbi in access point mode.
more complicated fix?
put the netgear's ip address in the tp-link's dmz.
Why are you needing the tp-link in there? the Orbi setup is quite capable and adding complexity to a network usually only causes problems.
penanghill
Sep 21, 2020Aspirant
Netgear support advised my reset button was faulty, so I am returning the product to the sales company.
