Soulprogression
Jul 13, 2020Tutor
AC75 Nighthawk Cannot Access Router Login, 401 Error, worked fine last night.
Ok, so here's the issue, and maybe it's just a temporary thing on Netgear's end? Last night, I jumped on routerlogin.com saved in my favorites so I could turn the wifi on. I typically keep it off mos...
Jul 14, 2020Guru - Experienced User
What modem is it connected to?
If you disconnect the R6020 from the modem, are you able to connect to it and access/use it ?
Soulprogression
Jul 21, 2020Tutor
Internet is working fine, as I mentioned I can connect via ethernet and do my thing, it's accessing the routerlogin page from my mac. I've actually been able to access it from my phone which is handy, and didn't work before. Also I think it's a safari issue because I've been able to get there and adjust settings on my mac using google chrome.
- SoulprogressionJul 21, 2020Tutor
Actually I just checked and now it's working through safari.... I'm guessing it was just a server issue or something on NetGear side.
Haribol!
Max
- plemansJul 22, 2020Guru - Experienced User
Eitherway I'm glad to hear its working again!
