lgc252's avatar
lgc252
Follower
Nov 26, 2019
AC750 - SETUP
HELP ... I cannot set-up this dual band extender.  Am I just stupid?
1 Reply
  • plemans's avatar
    1. Which extender? the mdel you linked to is a router
    2. Is that the router you're connecting to? No? which router are you connecting it to?
    Most of the device support pages have a video that walk you through install. As well as the manual has wps and manual install instructions. have you looked at the support page for your device?
    you can get there by going to netgear.com/support/    type in the actual model number. That'll have a support page with all the info I referenced to.
    If that doesn't help, explain more. Tell us where its failing and what issues exactly you're having.
