LesD
Dec 09, 2019Aspirant
AC750 cannot connect to my new xfinity router (AC 9560)
Anybody know if there is a Netgear WiFi Extender that'll connect to my ne xfinity router?
Dec 10, 2019Guru - Experienced User
Which xfinity router?
What actual extender do you have? you listed the d6000 which is a dsl modem/router.
Whats the firmware on the extender?
Extenders will connect to most consumer routers. They're designed that way. it might take some fiddline or using the manual setup method but you should be able to get it to connect.
What errors/problems are you having? A better description of where its failing can help us to help you.
You can get the manual, firmware, troubleshooting, and even videos of installing on the support site for your device.
go to netgear.com/support/ and type in your model number. It'll have all that info.
- LesDDec 10, 2019Aspirant
My Router is an Intel(R) Wireless-AC 9560 160MHz#2. Netgear technical conuld not connect my AC750 and suggested I either contact Intel to see what extender might connect or to try a more advanced extender. I am still waiting to hear from Intel.
- plemansDec 10, 2019Guru - Experienced User
The intel 9560 is a wireless card. Not an extender and not a router.
You can visit intel and update your drives for whatever device you have using this wireless chipset. Intel's earlier drives struggled a bit and had issues seeing many networks.
If you want help
1. look at your xifinity box. What model is it?
2. What device are you connecting that has the intel wifi chipset in it?
3. What firmware is on your extender?
Where is it failing?
Are you failing to see the extenders wifi broadcast?
Are you connecting to the extender but the extender isn't seeing the router's wifi?
Is it the password thats failing?
A better desciption of whats going on and what exact devices you're using can help us to help you.
- LesDDec 11, 2019Aspirant
Turns out that my Xfinity Gateway is a Technicolor CGM4140. But i am still looking for a wifi extender that will connect to this gateway.
