jsowro1963
Feb 04, 2024Follower
ac750 cannot set up to Spectum wifi6 router
Netgear ac750, having problems connecting router. If i try connecting Netgear_ext, turns off my SpectumSet-XXX, therefore I have no wifi connection to try setting up the extender. Any suggestions as...
Stephen378Baker
Feb 19, 2024Aspirant
You need to follow these steps to set up your router:
Connect an ethernet cable from the Spectrum modem to the internet port on the back of the Netgear router.
Plug in the power cable for both devices and wait for the WiFi LED to light up on the Netgear router.
Look on the router label for your router’s WiFi network name (SSID) and network key (password).
On your computer or mobile device, connect to the Netgear router’s WiFi network using the SSID and password.
Launch a web browser and enter http://www.routerlogin.net or http://www.routerlogin.com in the address bar. DogLikesBest
Log in with the default username and password (admin and password) or the ones you have changed.
Follow the on-screen instructions to complete the setup wizard.
If you want to enable WiFi 6 features on your Netgear router, you can do so by logging in to the router’s web interface and selecting the Enable AX check box under the Wireless Setup section.
I hope this helps you set up your router and enjoy a fast and reliable WiFi connection.
