SwedenGothic
Jun 23, 2019Aspirant
Ac750 Does not accept password
The device will not accept the password. Everything else seems fine, all relevant lights are shining. No i can't use web sign in since the device doesn not display netgear_ext network used for ma...
Christian_R
Jun 27, 2019NETGEAR Employee Retired
Hello SwedenGothic - Would you mind telling us what password you're referring to such as the WiFi password or admin page password?
~Christian
- SwedenGothicJun 27, 2019Aspirant
It is the wifi password.
- Christian_RJun 28, 2019NETGEAR Employee Retired
Hello SwedenGothic - Thanks for getting back. May you try holding down on the factory reset button for 15+ seconds. After doing so, the extender should factory reset and you will be able to go through the setup instructions again.
~Christian- DonizeteJul 06, 2019AspirantThe same problem is happening with me, i did all of steps, but still dont connect the wifi password
Thanks
