Carldrjr2000
Oct 31, 2024Follower
AC750 Dual Band Range Extender
I have a NetGear AC750 Dual Band WiFi Range Extender with a Verizon Router, S/N # ABJ24223638. I placed the Extender right next to the Router and plugged the Extender to a powered extension cord. The green power light came on, after pressing the WPS button a blinking amber light appeared. Then turned green but neither the Router nor the Device light’s came on. MY VERIZON ROUTER does not Have a WPS Button??????
These are the numbers for the AC750 WiFi Range Extender, MAC - 9C3DCF54B0FC,
SERIAL - 4AMA7878A0EDE & WPS PIN - 36991594
1 Reply
factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
