Ivan13
Jul 30, 2022Follower
AC750 Dual Band WiFi Range Extender Model EX6000
Hi, I have been using a Netgear 'AC750 Dual Band WiFi Range Extender Model EX6000' with a 'BT Home Hub5 - Type A' successfully for a number of years. Originally BT supplied me with their own branded Extender which unfortunately did not provide an adequate signal to the TV/TV Box in the remote location. I am now thinking of moving away from BT as my broadband supplier because of the high cost I have been paying and I am considering moving to Plusnet which I believe has a 'Plusnet Hub 2' hub which I understand is a rebranded BT hub. My question is should it be simple and straight forward to setup the 'AC750 Dual Band WiFi Range Extender Model EX6000' with the 'Plusnet Hub 2' hub? The reason I'm asking this question is because the Extender is now quite old and the Netgear support sides specifies that it no longer has software support. My thanks in anticipation of your feedback and advice.
1 Reply
It should just be factory reset the extender and then reinstall it to the new router.
Does that always work? Sadly, no.
Some of the ISP supplied modem/router combo devices can be a pain.But I'd try it and see how it goes
