Clement01
Mar 28, 2020Tutor
AC750 EX3700 - Incorrect PSK provided + Incorrect Router Password
Hi, I have set up my new AC750 EX3700 this morning and once the setup was all done my different devises could see the Router_2GEXT and Router_5GEXT WiFi networks perfectly. My issue comes when tryin...
Clement01
Mar 28, 2020Tutor
Hello,
The router is a Vodafone Wifi Hub.
I did use WPS, what is the installation wizard ? the programme of the router ?
Thanks
Mar 28, 2020Guru - Experienced User
Clement01 wrote:Hello,
Thanks
which Vodafone Wifi Hub?
The installation wizard is how you setup the extender without using wps. Wps works great but not all manufacturers code it the same so it doesn't always work. this is why there's the installation wizard.
there's a video on the support site (think its video 2) that shows it being used.
- Clement01Mar 28, 2020Tutor
the issue is that I when connecting to the router it asks me for the wifi password and then doesn't recognise it so I cannot go onto mywifiext.
the router is a Vox3.0v
