Clement01
Mar 28, 2020Tutor
AC750 EX3700 - Incorrect PSK provided + Incorrect Router Password
Hi, I have set up my new AC750 EX3700 this morning and once the setup was all done my different devises could see the Router_2GEXT and Router_5GEXT WiFi networks perfectly. My issue comes when tryin...
Mar 28, 2020Guru - Experienced User
Lets start over.
1. What are the led's indicating on the extender?
2. If you hardwiring into the extender, does it work?
3. When you were setting up the EX3700 using the smart wizard, is it able to connect to the router?
4. What device is giving you the psk warning?
Clement01
Mar 28, 2020Tutor
All leds are green. The only exception is that the Device Led is sometimes off.
Just did it, yes it works.
I just reset the extender to factory settings, and set it up again with the wizard.
This is now working on my all three devices. When I did it earlier I may have missed a step or did not reset the extender before doing it.
My professional laptop which uses a VPN to secure the connection. This error message comes as I am connecting to my home WiFi (so before logging onto the VPN).
My other two devices (personal laptap and phone) tell me the password is incorrect.
Thank you very much for your help,
Clement
- plemansMar 28, 2020Guru - Experienced User
Clement01 wrote:1. What are the led's indicating on the extender?
My other two devices (personal laptap and phone) tell me the password is incorrect.Thank you very much for your help,
Clement
so you've got it working now?
- Clement01Mar 29, 2020Tutor
yes this is all working. thank you very much
