jimncarol
Oct 09, 2020Tutor
AC750 extender / model EX2800---keeps dropping out.
Using 2 chromebooks, both units showing same problem. WiFi drops out completely on a regular basis. Signal will come back on it's own at times and other times it won't. This morning it wouldn't stay ...
- Oct 10, 2020
From the sound of it you have the extender connected to the other extender. Which is why you get the ext extension 2x.
try re-running setup and making sure to have them connected to the router.
Also, if you live in close living environments (apartment, condo, ect), try doing a channel scan to ensure you're on the best available channels for both 2.4ghz and 5ghz.
Also, keep in mind that 2.4ghz is more sensitive to interference. especial in crowded environements. it has less available bandwidth, broadcasts further, and through more materials than 5ghz. so try to make sure as many devices as possible are on the 5ghz as it'll have the best speeds and least interference.
jimncarol
Oct 10, 2020Tutor
Router is telco supplied / Comtrend nexus link 3120
Yes, there is another extender (same make and model) located in a separate bulding probably 12 feet from router which sits in front of a window with 1 wood frame wall between them. Doesn't get used as much as the other but shows same symptoms at times. Used mainly for streaming Roku.
The main extender sits 35-40 feet in straight line from router through an open door and no walls. (At end of a hallway.)
I believe I used the installation assistant for the setup..
Oct 10, 2020Guru - Experienced User
- jimncarolOct 10, 2020Tutor
OK! Super busy this weekend, will try for another setup and see what happens.
Thanks for quick reply!!!
