v015eyjd
Mar 24, 2020Initiate
AC750 Extender Ethernet Enabled Device
I have an AC750 WiFi Range Extender Model EX6100v2. I want to connect it up in Extender Mode. There is a picture in the Quick Start Guide under the heading "Connect to an Ethernet-Enabled Device. ...
Mar 24, 2020Guru - Experienced User
You can do that. As I've done something simlar in the past (not recently).
Its just something to keep in mind that even though those devices are hardwired in, they're still running off the wireless between the router and the extender. And that extender is a basic AC750 device. If you're trying to push a bunch of bandwidth through it, an upgrade to something with a a wider/higher throughput device might be better. If you're not transferring that high of bandwidth, then you'd probably be alright*.
*depending on connection strength, distance, interference, etc.
v015eyjd
Mar 25, 2020Initiate
plemans wrote:You can do that. As I've done something simlar in the past (not recently).
Yes, bandwidth should be minor. No movie streaming, etc. Just sending commands from my Crestron controller to the Roku and TiVo via Ethernet connection. The TV and AV Receiver have an IR input, which is sent from the Crestron controller to the device via an IRP2 - IR Emitter Probe w/Terminal Block Connector
