parkero95
Jun 30, 2017Follower
AC750 extender with AC1750 router
Will the AC750 extender work with the R6300v2 AC1750 router? Do the numbers have to match? I understand the MBPS will be lower on the extender but as long as it will work, that doesn't bother me.
1 Reply
- pcdoctorwAspirant
Yes it will work, because you have purchased the correct device. AC routers will go well with AC extrenders but they do not go with N specs.
You are fine.
