DarrenAinsley
Mar 07, 2022Tutor
AC750 Model Ex 3110 wifi connected but no internet access
Hi I'm having issues with my wifi extenders. Worked fine till a couple of weeks ago but now constantly getting wifi connected but no internet access. The basic wifi signal still works fine but everyt...
DarrenAinsley
Mar 08, 2022Tutor
Hi,
Slingshot Dual Band AC1600 Gigabit Gateway with VoIP
Netgear online installation.
2 extenders 1 upstairs / 1 downstairs router in the main living room downstairs.
issue through out the house can connect to slingshot wifi but weak signal but can't access the internet when connected to wifi 2GEXT / wifi 5G EXT.
Thanks,
Darren
Mar 09, 2022Guru - Experienced User
what model slingshot is it? AC1600 is a speed
Both extenders are having the same issue?
- DarrenAinsleyMar 09, 2022Tutor
Model NF18ACV
VDSL/FIBRE Dual Band AC 1600 Gigabit Gateway with VoIP description on the back of router.
Issue with both extenders although 4 green lights on both.
Thanks
Darren
- plemansMar 09, 2022Guru - Experienced User
do you have the issue if only running 1 extender?
yes still having issues with only 1 extender running.
Also now getting privacy warnings have tried toggling the private address button on both 2.4 and 5 G networks no luck although basic wifi still functioning.
Thanks,
Darren
