DarrenAinsley
Mar 07, 2022Tutor
AC750 Model Ex 3110 wifi connected but no internet access
Hi I'm having issues with my wifi extenders. Worked fine till a couple of weeks ago but now constantly getting wifi connected but no internet access. The basic wifi signal still works fine but everyt...
Mar 09, 2022Guru - Experienced User
do you have the issue if only running 1 extender?
DarrenAinsley
Mar 09, 2022Tutor
yes still having issues with only 1 extender running.
Also now getting privacy warnings have tried toggling the private address button on both 2.4 and 5 G networks no luck although basic wifi still functioning.
Thanks,
Darren
- plemansMar 10, 2022Guru - Experienced User
Whenever 2 devices are having the same issue, it makes me suspect what they're connecting to.
Becuase its incredible rare for 2 devices to go bad at the same time (absent storms/power surges)
any chance you have an old router sitting around you could connect them to to test with?
Maybe the ISP pushed new firmware to the router and its causing issues.
