Krykit_2's avatar
Krykit_2
Follower
May 10, 2025
AC750 (model EX3110) is connecting to the router but not allowing internet access
I just purchased the AC750 model EX3110 range extender. I can get the device to connect to the router but, it will not connect to the internet.  The main router is a Spectrum WiFi E6. I connected the device using the Assistant and all went through well. I show both 2.4 and 5G connections. However when I connect any device (laptop, tablet, mobile device) to the extended network, it says "Connected, no internet." or "Action needed, no internet." I did a factory reset and checked if the firmware needed to be updated. Everything seems to check out... what am I missing?
1 Reply
  • plemans's avatar
    What actual spectrum modem? (model)
    there was one version that was garbage and pretty much every brands extenders had issues.
    Also, are you using wpa2/wpa3 mixed mode?
