alpot
Feb 19, 2020Aspirant
AC750 Model EX3700 and Synology Rt1900ac
Hi, I can't get my new EX3700 AC750 extender to work with Synology RT1900AC. I can complete the setup but when I try a device to connect to it, it can only go as far as 'Obtaining IP Address'. ...
Feb 19, 2020Guru - Experienced User
Are you setting it up with the wps setup option or using the smart installation wizard?
Try the smart installation wizard.
Firmware on your extender?
- alpotFeb 19, 2020Aspirant
Hi,
Yes, we are using the the smart wizard.
The Firmware version is v1.0.0.76_1.0.49.
alpot
