alpot
Feb 19, 2020Aspirant
AC750 Model EX3700 and Synology Rt1900ac
Hi, I can't get my new EX3700 AC750 extender to work with Synology RT1900AC. I can complete the setup but when I try a device to connect to it, it can only go as far as 'Obtaining IP Address'. ...
alpot
Hi,
Yes, everything works fine in an AP mode.
I looked at the devices connected to my router and I can see the 2 MAC addresses of the extender. However, I don't see any IP address assigned. Is that normal?
I'll try to contact Synology about this issue and see if they can help.
Thank you.
alpot
Feb 19, 2020Guru - Experienced User
alpot wrote:
Hi,
-Not necessarily. Usually the router assigns an IP address to the extender and then the devices connected.
- alpotFeb 19, 2020Aspirant
Hi,
I've contacted Synlogy and they asked the following questoins:
1. Does the Netgear router as an extender means the WDS mode?
2. Whether the Netgear router can only connect with the same brand router when it is used as an extender.
alpot
- plemansFeb 20, 2020Guru - Experienced User
alpot wrote:Hi,
1. Does the Netgear router as an extender means the WDS mode?----no idea what you're trying to say here.
2. Whether the Netgear router can only connect with the same brand router when it is used as an extender.-----no it can work with most routers. I've read of a few ISP routers that have issues but in those cases, it wasn't isolated to netgear extenders. All the extenders that were tried to connect had issues.
alpot
