xoccerplaya
Sep 02, 2021Aspirant
AC750 Model EX3700 Connected to internet but can't get back to settings
Recently set up AC750. I went through the set up no problem, created the new extended networks and connected to them. The internet works but now I am unable to get back into its settings via the defa...
- Sep 02, 2021
Log into your router and look for its attached devices page (or equivelent for your router).
It should have the IP address for the extender.
Use that ip address to connect/manage the device.
xoccerplaya
Thank you! I was able to find the address and finally get back into the settings.
I set up the fastlane but as soon as that set up the extender won't connect to the internet...
The extended network is created but won't connect to the internet. No lights are on other than the power. Not sure what went wrong
Sep 03, 2021Guru - Experienced User
You can always factory reset and reinstall as you did before to get it working. push and hold reset for 7-15 seconds while powered on
