TVincent
Mar 18, 2023Aspirant
AC750 Model EX3700 keeps asking me for sign-in
Why is my extender suddenly asking me to sign in? Recent change after years of use and means I have lost e.g. Amazon access etc on TV and mobile phone. Why has this suddenly started to happen? How do...
Mar 19, 2023Guru - Experienced User
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
TVincent
Mar 20, 2023Aspirant
Hi, I didn't use WPS to set up but will try a re-set. Thanks
- plemansMar 20, 2023Guru - Experienced User
If that doesn't work what router are you connecting it to?
What firmware is on the extender?
- TVincentMar 27, 2023Aspirant
Hi, I've now got a Netgear account but when I try and sign in when requested, the sign in button never works, what ever access I'm using (TV, mobile phone etc), it just stays on the input screen. Any advice?
- plemansMar 27, 2023Guru - Experienced User
Try a different pc/laptop/device and/or web browser
but I've tried it on all my devices, same result. I don't get an option to change web browser on the TV which is the main issue. I think I shall just buy a new extender that doesn't require this option. It's really annoying, so has put me off the product anyway.
