johnnySwindon
Aug 02, 2024Follower
AC750 Model EX3700 stopped working wouldn't connect to internet
Hi just some info that might just stop you going insane with Netgear. My AC750 range extender decided to throw a wobbley and stopped working. After many resets and attempts at a set up both with ...
Aug 02, 2024Guru - Experienced User
Not sure what router you have but the EX3700 is a pretty old/slow performing extender.
If you have anything from a newer generation, might be worth upgrading if you need half decent speeds for the extenders usage
