Challenger_360
Feb 16, 2021Aspirant
AC750 Model EX6100v2 Will not connect to routor
Help Please, Just got home after 6 months away and my AC750 EX6100v2 will not connect to the router. I left my router from Frontier running but I shut off the AC750 wifi extender because I was no...
Feb 16, 2021Guru - Experienced User
It doesn't self terminate. :)
Did you push and hold reset for 7-15 seconds while its powered on?
What do all the led's do?
- Challenger_360Feb 17, 2021Aspirant
Q: Did you push and hold reset for 7-15 seconds while it’s powered on?
A: Yes that was done and all it did was shut off the power and made the power light flash amber and green. Router and extender lights flashed red and blue as well.
Q: What do all the led's do?
A: For the normal start up. After releasing the power button the power light stayed amber for 74 seconds. Then a quick .5 second flash of blue light for both extender and router followed by a .5 second flash of red for both extender and router. Then all but the power button goes out. Nothing other than the power button shows any light.- plemansFeb 17, 2021Guru - Experienced User
and what color is that power light?
The power light is a steady green.
