rt454
Apr 14, 2020Aspirant
AC750 not seen by router
I've had this Netgear extender in wifi Extender mode for a couple of years, half way between my router and the attic, but it's been quite unreliable due to the distance. So i planned to use it in acc...
rt454
it's model EX6000. The router is supplied by my broadnband company, a virgin media hub 3 I think, their latest model. They upgraded it for me because their previous model also had unreliable wifi connection to the extender. Hence ny giving up and going for a direct wired connection. The firmware is the original, I did try updating it but it wouldn't work when I followed the steps in the manual, Page Not Found I think it said, I assumed because it's not a current model. Should I re-try that as a first step?
Apr 14, 2020Guru - Experienced User
with a hardwired connection, it needs to be setup in access point mode. did you do this?
there's also a forum on virgin media for connecting ot the super hub. here's one post for instance
- rt454Apr 14, 2020Aspirant
Yes it's in Access Point mode. Devices will connect to the extender but the extender won't connect to the router. I've even tried a different ethernet cable. Thanks to all for helping btw.
- plemansApr 15, 2020Guru - Experienced User
What firmware is on the EX6000?
Have you connected a pc to the end of the cable to ensure the cable/connectors are good?
When the extender is in extender mode (not access point mode), does the ethernet port work?
- rt454Apr 15, 2020Aspirant
It's the original firmware, I was unable to update when I tried. I've tried different cables so I dont think it's that, plus the ethernet cable I tried is usually connected to my daughter's PS4 so I'm sure it works. Is the IP conflict mentioned by the helpline a red herring?
