jandro
Jan 04, 2021Follower
AC750 wifi extender model EX3110 unable to connect
I recently bought this product. My roommate set it up so that the SSID name is changed. It cant connect to the internet at all. So I tried to reset the device to use the nighthawk app and now when it...
Jan 04, 2021Guru - Experienced User
What router are you connecting it to?
What firmware is on the extender?
Have you tried factory resetting it (push and hold reset for 7-15 seconds while its powered on) and then doing a manual install using the installation assistant?
