JohnAus
Nov 15, 2019Aspirant
AC750 WiFi range extender duplicate virtual MAC addresses
I have setup the extender to increase the range of my existing WiFi router. The extender gives all devices that connect to the extender the same virtual MAC address. This address is the same as t...
Christian_R
Nov 26, 2019NETGEAR Employee Retired
Hello JohnAus,
The devices that are connected to the extender, are they able to go online? Also, would you mind telling me if you have address reservation enabled on your router and the model number of your router?
Thanks,
Christian
JohnAus
Nov 27, 2019Aspirant
Hi Christian. Thanks for replying to my question.
Yes, all the devices are able to go online.
My router is a Netgear D7000v2.
By address reservation do you mean static/reserved IP addresses? If so, no the router assigns addresses via DHCP
One extra complication that I have not mentioned so far is that the WiFi network that the extender connects to is provided by a KoalaSafe Dome device. https://koalasafe.com/dome.html
This is a device that plugs into the router and provides it's own wireless network. The extender then provides extra coverage for this wireless network.
According to this page, the EX6100v2 should be compatible with my KoalaSafe device. http://discuss.koalasafe.com/t/extenders-that-work-with-koalasafe/283
Any more questions, please let me know.
Thank you
- Christian_RDec 04, 2019NETGEAR Employee Retired
Hi JohnAus,
Thanks for getting back! I'd like for our support team to reach out to you for further investigation. Would you mind sending me a private message with your contact info and serial number.Thanks!
Christian
- JohnAusDec 05, 2019Aspirant
Hi Christian. I've just sent you a private message.
Thanks
John
