WalterLee
Mar 18, 2020Guide
AC750 WiFi Range Extender Essentials Edition experiencing a dropping in speed/performance over time
After using this wifi extender with my ASUS RT-AC3100 router I was happy with the performace of the connection which was 10mbps download speed on my computer. I use this product as a wifi extender an...
- Mar 21, 2020
Found the problem, In my router settings I saw that my speed was limited to 2mbps changed it back to what it was, it must've been my brother trying to keep his high speeds
WalterLee
Mar 20, 2020Guide
I have just found something very wierd. My download speed using my laptop connecting to my wifi extender's 2.4ghz band got 12mbps in the room where my computer's download speed is 200kbps!!! I think that there is something very wrong with either my ethernet port or computer since this shouldn't be happening
Mar 20, 2020Guru - Experienced User
again, I'd try borrowing or using a different device to do the testing. you're last post that gets the appropriate speeds with a different device seems to indicate that.
- WalterLeeMar 20, 2020Guide
Ok, so I found my old laptop that has an Ethernet port and go 50mbps with the wifi extender connected in the same room as my computer so I can confirm that it is my computer that is somehow limiting this ludicrous speed.
do you know what to do im kinda lost after spending time looking for an answer
