WalterLee
Mar 18, 2020Guide
AC750 WiFi Range Extender Essentials Edition experiencing a dropping in speed/performance over time
After using this wifi extender with my ASUS RT-AC3100 router I was happy with the performace of the connection which was 10mbps download speed on my computer. I use this product as a wifi extender an...
- Mar 21, 2020
Found the problem, In my router settings I saw that my speed was limited to 2mbps changed it back to what it was, it must've been my brother trying to keep his high speeds
Mar 20, 2020Guru - Experienced User
again, I'd try borrowing or using a different device to do the testing. you're last post that gets the appropriate speeds with a different device seems to indicate that.
WalterLee
Mar 20, 2020Guide
Ok, so I found my old laptop that has an Ethernet port and go 50mbps with the wifi extender connected in the same room as my computer so I can confirm that it is my computer that is somehow limiting this ludicrous speed.
