Chris7off's avatar
Chris7off
Follower
Apr 19, 2022
AC750 WiFi Range Extender (EX3700)
Hi, I’ve purchased this item from Amazon and before setting this up I would like some help so I get this right 🙂 I need to add WiFi to an outside building which is receiving a signal from the router but not covering the whole area… so, I purchased this item to hopefully resolve. I do have cables running back to a switch connected to the main router so I can use a cable to connect back to the switch and use the AP option? Alternatively I can use the WiFi extender option if placed in an area that has the WiFi signal? My main concern is I want to be able to connect to the CCTV and other monitoring devices that are connected to the main WiFi… is this going to work as this will have a different name? Like daveswifi_ext rather than daveswifi which the main one is? Any help appreciated, thanks in advance
1 Reply
  • plemans's avatar
    If you can hardwire it in and run it in access point mode, it'll have a lot better performance then in extender mode.
    The only issue with the different name is setting the devices you want on it to use that wifi network's ssid.
