NicolasS12
Apr 19, 2019Aspirant
AC750 WiFi Range Extender No Internet
I am having issues with my product I never had this issue before and everything started to happen when I got changed the router password from the new router. I was instructed to change the password f...
Apr 19, 2019Guru - Experienced User
The ex3700 might not have the changed wifi password for connecting to the router. I'd reset the device (hold the reset button for 7-10 seconds) and then redo your setup. this will make sure you have the correct password so they communicate correctly. Whenever you change the routers wifi password, you have to change it within the extender for how it connects to the router. You can go into the extender wired and redo the setup process as well. Either way works. I'll post the link for the manual, firmware, faq at the end for you to look at.
- NicolasS12Apr 19, 2019Aspirant
I tried that already, I also contacted my network provider and they told me that the WPS is enabled and everything is working fine on their end and don't know why the extender is not picking up internet they also gave me a support number for netgear.
