JohnVSB
Dec 02, 2019Aspirant
AC750 wifi range extender speed issue
Hello, I've successfully setup the extender by WPS but the speed is very poor. With a speed test i'm getting 200+MBS from the router wifi but only 19mbs from the extender using 5G and 16mbs for 2G wi...
Dec 02, 2019Guru - Experienced User
wifi extenders are sensitive to many different factors. These include hvac within your house, the materials of your house, how close to the router they are, wifi interference from multiple networks, to even random wifi interference from malfunctioning devices.
a couple things you can try and then I'll link to an article on how to optimzie extenders.
1. move the extender closer to the router. It needs a good signal to retransmit.
2. move the extender to a different outlet. Sometimes simple things like metal hvac within the walls can block signals.
3. Try a different wifi channel. maybe there's interference on the channel you're one.
https://kb.netgear.com/25508/Where-should-I-place-my-NETGEAR-Wi-Fi-range-extender
https://www.tomsguide.com/us/wifi-extender-setup-guide,review-4133.html
What actual model do you have? AC750 is a speed not a model.
have you recently updated the firmware on it? Which version are you on?
What is your home materials? this is kind of key
- JohnVSBDec 02, 2019Aspirant
Thanks for the quick repy.
I have tried several different outlets including 1 in the same room as the router. All give approximately the same speed.
I have the EX3700 AC750 wifi range extender.
I am on a Mac and don't see a way to install the firmware update
Brick house, 2x6 studs, drywall
thanks
- plemansDec 03, 2019Guru - Experienced User
The firmware install instructions are the same for a mac if you're logging into it via a browser.
If you're on the support site for your device, the 3rd video on the "top support videos" walks you through a firmware update.
https://www.netgear.com/support/product/EX3700.aspx
try updating, factory resetting, and reinstalling the extender and see if this helps.
