heidilusk's avatar
heidilusk
Follower
Jul 30, 2020
AC750 Wifi Range Extender will not connect to device for set up
I don't have a WPS button on my router so I am following the instructions and trying to connect my device to the netgear_ext network but when I do it says there is no internet. I've tried it several times, turned the ext on and off, etc. So if I can't get connected to the ext, what can I do?
1 Reply
  • plemans's avatar
    Once you connect to the extender, you need to run the setup wizard.
    Start fresh. Factory reset the extender by pushing and holding reset for 7-15 seconds while its powered on. Then try the setup.
    Try hardwiring into the extender via the ethernet port. (disable the wifi on the device you connect to the extender so it doesn't default back to wifi). Then try running the setup wizard.
    What router are you connecting to?
