sonofmusrol
Nov 30, 2021Follower
Access point speed very slow after a minute
Hello, I have recently installed a new access point to my router, the speed is nice and fast for the first minute, then it will slow considerably after a minute or two. When I set the radio mode ...
Nov 30, 2021Guru - Experienced User
One thing I'd test.
direct connect the ap to the BT smarthub (not through the switch) and power it with its own power supply. (fairly common power supply for the WAX610). See if it runs and stays stable.
If it does, then connect it to the switch with still using your own power supply.
Just trying to see if its a power issue, a switch issue, or if it happens directly connected.
