Tntmold
Feb 03, 2012Novice
Access pont works one location but not another
I have a wgr614v9 configured as an access point with a short cable next to the primary router, works great, but when moved to the end of a 50 ft cat5 it no longer works. Ethernet light blinks slow gr...
fordem
Feb 03, 2012Mentor
The cable is the only variable there - what sort of cable tester are you using?
Some of them just check for continuity and pay no attention to split pairs, attenuation and cross-talk.
