Tntmold
Feb 03, 2012Novice
Access pont works one location but not another
I have a wgr614v9 configured as an access point with a short cable next to the primary router, works great, but when moved to the end of a 50 ft cat5 it no longer works. Ethernet light blinks slow gr...
Tntmold
Feb 04, 2012Novice
I don know the brand name - its something I picked up from tiger years ago called a "multi-network cable tester" and has bnc, 10 baseT, token ring, att258a, and eia/tia568. It hooks to each end of the cable and has led indicators for each pair. All pairs test good, but I believe it's only checking continuity and not noise
