Tntmold
Feb 03, 2012Novice
Access pont works one location but not another
I have a wgr614v9 configured as an access point with a short cable next to the primary router, works great, but when moved to the end of a 50 ft cat5 it no longer works. Ethernet light blinks slow gr...
fordem
Feb 04, 2012Mentor
Exactly my point - it checks for continuity and nothing more - you need to make sure the cable is properly wired, and yes, a long miswired cable will work under some circumstances and not under others.
