neil154
Dec 14, 2013Aspirant
Accessing My WGR614v8 in Access Point Mode
I have my WGR614v8 setup as an access point. Is there any way to review and reconfigure it thru my wireless network or is it only accessable by connecting it by ethernet directly to my PC?
jmizoguchi
Dec 14, 2013Virtuoso
If you have setup static IP on WGR and IP is same lan subnet as your existing then should work fine. You can not use WAN/Internet port when used as access point. Must to use on of the LAN ports to existing network
otherwise all should be okay
