Daali
Jan 01, 2011Aspirant
Accessing WG302 via http since the year changed?
I am getting a "Self Certificate" page since this morning accessing my WG302's.
Any insight?
Any insight?
- DaaliAspirantThe certificate expired on 12/31/2010 6:59 PM.
I guess we are going to need an updated firmware? - jmizoguchiVirtuosoDoesn't look like part of WGxx interface.
This show after you login WGxx? - DaaliAspirantIt is an expired certificate issue. Certificate expired 12/31/2010 6:59PM
I finally got the page to come up with that error after powering down one of the APs.
The AP still works, you just cannot configure it.
That screenshot is the results of login.tri after you log in successfully. It is the same page regardless of browser(firefox, chrome, IE) - msnancyAspirantWe doubt that this is page came from WG302. Probably ou are redirected to another link.
Do you have other device connected behind the WG302?
Can you please give us your network setup in details. - jmizoguchiVirtuoso
reset the browser on IE... and test. forget rest of chrome.. lol
also go to IE browser and check certificate
tool>setting and security.... might look for one and delete
also helps to post actual screenshot of whole and just portion like you did.. - DaaliAspirant
msnancy wrote: We doubt that this is page came from WG302. Probably ou are redirected to another link.
Sure thing.
DSL <-> Cisco ASA5505 <-> Cisco Catalyst 3560 <-> WG302v1
I have 15 of these at work as well. I just VPN'd to work and checked them all, same issue. If I power one down, and up, I can get the expired Certificate page that has 12/31/2010 6:59PM as the end date.
Work network is:
Dual T1s<-> Pair of Cisco ASA5520's <-> 20 Cisco Catalyst 3560's <-> 15 WG302v1 - DaaliAspirant
jmizoguchi wrote: reset the browser on IE... and test. forget rest of chrome.. lol
Ok, I took another SS from a computer at work, logging into one.
I reset that PC's IE, and checked Tools->options -> content _> cleared SSL state
Also, looked through certificates, seeing if I could find one that had that date, I could not. - jmizoguchiVirtuosoworth a try is take one AP unit remove from the existing
reset the unit and test between the pc and WG only... it issues goes away, there must be certificate in the this model has expired. been WGxx is out on market so long may did not expect to run this long? lol - DaaliAspirant
jmizoguchi wrote: worth a try is take one AP unit remove from the existing
It is the cert in the model. I will wait to reset one at work, lol. Once it is reset, I will not be able to get back in via the browser, and I do not have a null modem cable at the house(notebook bag is at work lol).
If Netgear doesn't release an update, I could always pay for DD-WRT activation.
Thanks for your help. - jmizoguchiVirtuosothat login.tri does not look coming from WG302.
