Daali
Jan 01, 2011Aspirant
Accessing WG302 via http since the year changed?
I am getting a "Self Certificate" page since this morning accessing my WG302's. Any insight?
jmizoguchi
Jan 01, 2011Virtuoso
I left it at work on purpose too. lol. Oh well.
I keep spare on home office just incase......
I hear you about the login.tri. The weirdness actually starts before you log in. On the login page, the NetGear logo appears as a red [ X ](broken link) image, where as yesterday it was there. Once you click the log in now button(if successful), the page login.tri pops up with the above.
most interface are HTML *.htm, html
or like the prosafe routers (https://192.168.70.1/scgi-bin/index.htm) on HTTPS
Unfortunately, I don't know the unit so I would able to test my lab.
I think only way to to use PC and WG directly and reset the WG to see the issues.
if you let WG hook up to active network, NTP will pickup the time so you have to remove and see if you can test that way by reset and work with default which should loose the DATE/TIME.
