captshaq
Jun 02, 2013Aspirant
ACL on Router and Extender?
I have ACL on my router (Linksys) and it's working well. Now I added the NG 2500RP extender. Do I need to add each end-point to the router's ACL itself, or is it enough to have the extender's MAC addr...
captshaq
Yes, already installed. The issue is that with my home network being extended - I have all the more reason to have an ACL. If the extender doesn't do it I'm thinking of wiring a separate access point from one of my router's physical ports. It may be less complicated that way.
jmizoguchi wrote: Did you already installed?
ACL is preference but again it seems extender and ACL can conflict
This needs to tested and see ACL will work or not
