Kstonequist's avatar
Kstonequist
Follower
Sep 02, 2017
Add a wired camera
Hello,
 One of my cameras is just far enough out of range to where it does not always work. Is there any way of  hardwiring  just that one camera to the system? It's only about 150 feet away, but the line of sight is not so good. It is slightly downhill from the base, and there are trees in between.
Thanks!
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Kstonequist
    If your extender has a ethernet port then yes you could wire a camera to it.
    DarrenM
