Ventur-M
Feb 25, 2024Follower
Add additional product to existing Night Hawk AC 1900 for more range
Can you add a booster to an existing Wi-fi extender? I have a Night hawk AC 1900 dual band now and would like to increase range further. Thank you
michaelkenward
Feb 25, 2024Guru - Experienced User
Netgear makes a whole range of wifi extenders.
WiFi Boosters & Extenders | Wifi Range Extenders | NETGEAR
But depending in what you want to achieve there may be other options.
It might help to start by telling people what router you are using now and what you want to achieve.
Which Netgear device is it?
AC1900 is not a unique Netgear model number. (Netgear lists a dozen or so of those.) Many devices come with the AC/AX tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.
Look at the label on the device for the Model Number. And, if there is one, include the "V" bit to show the hardware version. If there is no V number, then you have V1.
