davenicsnr
Sep 29, 2020Aspirant
Add another N300 extender
Recently changed broadband supplier and in order to ensure better wifi cover I purchased BT Mini Whole Home Wi-Fi - Three Discs. Not a good choice so returned to BT. I have an N300 extender which gi...
- Sep 30, 2020
here's the issue.
N300 is a single band 2.4ghz device. 2.4ghz is slow. And suseptible to interference.
And I usually recommend people move to a full triband mesh system if their needing more than 1 extender.
Reason why is extenders by their very nature drop throughput (speed) 50%. Plus you end up with another ssid name to have to switch to. It gets even worse when you add another extender to the situation with another ssid. And the speeds drop even more if you're connecting an extender to another extender.
tribands extenders don't suffer from the same speed hit and can use the same ssid as the primary.
This tends to make them more stable and easier to use.
Its even better with the triband mesh systems like orbi as their designed for it and have the router controlling the system.
Sep 29, 2020Guru - Experienced User
Its just to ensure that the extenders are connecting back to the router and not to each other.
Easiest way is just to power off the other extender when you're setting up the new one.
